17" Wheel Question
Old Nov 18, 2007 | 09:24 AM
dferkler's Avatar
dferkler
Default 17" Wheel Question
Is anyone running 17x10.5 rims? I ordered a set and am affraid they are not going to fit. I was looking for a 9.5 but none were available.
Old Nov 22, 2007 | 11:03 PM
Poco's Avatar
Poco
Default RE: 17" Wheel Question
If you ordered a set(4) the 10.5 wide wheel won't prolly fit up front,brake calipers or strut assembly right in the way .You could access the Tire Rack web-site and speak to their tech reps for exact wheel sizes you need.
Old Aug 14, 2008 | 06:49 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
You can fit 10.5's on all four corners of an S197 if you go Griggs GR-40 suspension or serious suspension mods. Barring that, you will have to check your tolerances close and possibly still need to roll the fenders as they will fit on back.
Running 17"x10.5"s is going to leave you quite the fender gap unless you do some seriously short springs (not recommended) or go HIGH profile (50~55 series tires) also not recommended.
I would recommend going 18"x10"s for a much easier and more common fit.
Jazzer
Old Aug 14, 2008 | 09:28 PM
Sleeper_08's Avatar
Sleeper_08
Per my signature I'm running 18 x 9.5 rims on all four corners with 285/40/18. The trick is to get the right 45 mm offset which the Steeda wheels have.
No rubbing until I lowered the car with the Steeda Competititon springs and then only slight rubbing on the plastic front inner fenderwells on full lock.
Old Aug 15, 2008 | 05:18 PM
RodeoFlyer's Avatar
RodeoFlyer
Wink
I would send the wheels right back and get the proper size. That's way too much wheel IMO. You can run 285's on a 9.5 wheel if you need to.
Jazzer - the S197 comes from the factory with rolled fender lips
Tivo304
Aug 28, 2023 12:19 PM
Luke9222
Oct 22, 2015 11:55 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
