Caster/Camber Plates
ORIGINAL: Fred Malibu
^^^ groovy dude.. lol
for the 110 for the bolts I ALMOST want to spend the extra $ and get the adj kit..
...nah
Thanks for your help!
I'll go check some local places tomorrow.
...nah
really nice parts......
yeah. the plates give you more adjustability, but if thats your only worry then the bolts will fix you up just fine. but i will agree with the statement that the plates will give you more of a range when aligning. however i just dont know about them. it kinda worries me that theres a whole new part being added instead of an existing one being replaced. idk... maybe thats just me...
Before you try and make fun of someones knowledge and help please be correct. please take a look at the link below and explain to me how camber bolts or plates are going to increase thespacing between the caliper and wheel?
If you notice the wheel, rotor, caliper are all attached to the spindle. when installing camber bolts you are adjusting the spindle arm everything attached moves with it. with your thinking the top of the wheels are going to move out a degree or twoand the rotor and caliper are going to stay as there were? How's that possible?
http://www.swaaggs.com/documents/strut.pdf
^^ negative ghostrider.. lol
the wheels will clear the caliper better if the tilt is gone.. they are just leaning in too much and need to be balanced back out..
plus I heard that wheel spacers are bad for the car..
the 18" OEMs should fit the 6 no problem.. I just lowered mine 2" so I need to fix the camber..
I still got no links for products.. lol
maestro1024
Sep 21, 2015 02:40 PM
