Caster/Camber Plates
Old Jan 28, 2008 | 06:23 PM
Fred Malibu's Avatar
Fred Malibu
Default Caster/Camber Plates
Hey guys (I posted this in handling but it only has like 3 hits now and 2 of them are mine lol).
Last month I dropped my car with Sportlines and I decided I need caster/camber plates..
Do you guys have any suggestions (links) for the products?
Also I am looking for a decent set of shocks to replace my stockers (its a harsh *** ride now..lol)
I WANT d-specs, but I'm about $450 short of them..lol..
Any cheaper but still quality shocks?
Thanks.
FM
Old Jan 28, 2008 | 08:14 PM
pat6674u's Avatar
pat6674u
Default RE: Caster/Camber Plates
Won't be of any help but I'm curious as to what these do as well.
Old Jan 28, 2008 | 08:19 PM
Fred Malibu
oo I know that they do..lol
I just want someone that has put them on to gimme a good company..
Old Jan 29, 2008 | 03:38 PM
07lane40's Avatar
07lane40
just get the camber bolts? your tires are wearing on the inside right? mine did when i got my sportlines on them. all it takes to fix them is a camber bolt kit and a re-alignment. no need for a 250 dollar camber kit. the bolts will fix you right up.
Old Jan 29, 2008 | 03:41 PM
Fred Malibu
Well thats comforting
so you got a link to these camber bolts?
My problem is that now my wheels almost touch my calipers because they lean inwards a bit..
I need to push them back out so I have space in there again..
Old Jan 29, 2008 | 04:09 PM
schapman's Avatar
schapman
neither camber bolts or plates will fix that.if that your problem you need wheel spacers
Old Jan 29, 2008 | 04:21 PM
Fred Malibu
^^ negative ghostrider.. lol
the wheels will clear the caliper better if the tilt is gone.. they are just leaning in too much and need to be balanced back out..
plus I heard that wheel spacers are bad for the car..
the 18" OEMs should fit the 6 no problem.. I just lowered mine 2" so I need to fix the camber..
I still got no links for products.. lol
Old Jan 29, 2008 | 08:07 PM
07lane40's Avatar
07lane40
the bolts are available at tire discounters, they will run you about 110 dollars installed and aligned. it was a simple fix and only take about an hour, i dont have a link that i can find, but search mustang camber bolts on google. but they should be readily available to install at tire discounters, its not a part they have to order.
Old Jan 29, 2008 | 08:09 PM
07lane40's Avatar
07lane40
i think theyre on americanmuscle.com too... but im not positive about that.
Old Jan 29, 2008 | 08:13 PM
Fred Malibu
^^^ groovy dude.. lol
for the 110 for the bolts I ALMOST want to spend the extra $ and get the adj kit..
...nah
Thanks for your help!
I'll go check some local places tomorrow.
