Handling issues with 275/40/18's on all 4's?
RE: Handling issues with 275/40/18's on all 4's?
ORIGINAL: F1Fan
Your car will also be 1/2" shorter and your wheels wells will look even more empty than before.
Just a point of clarification your car will only be 1/4" lower....the 275/40x18 are 1/2" smaller in diameter which translates to 1/4" lower in radius (aka ride hight)....
ORIGINAL: 2007GT/CS
Did you get your MT1s and 285's yet?
ORIGINAL: UrS4
[sm=closed.gif] You could try 285/40/18 all around, it shouldn't rub up front if the GT500 wheel offset is 45mm.
I've run a few HPDEs with 275/40s all the way around and all I can say is that they are great. The car just seems to have limitless grip(okay so I can brake it loose if I want). It is also nice that I can rotate my tires...which I need to do.
mungodrums
10-07-2015 04:01 AM
Dragonus18
09-09-2015 01:21 AM
mungodrums
Suspension
09-07-2015 07:28 PM
mungodrums
Suspension
09-07-2015 07:22 PM
