strut mount recomendations
Old Apr 15, 2008 | 09:48 PM
JTE_502's Avatar
JTE_502
Default strut mount recomendations
So far I've got the Eibach Pro Kit springs and a Spohn adj Panhard bar. I've just been buying parts one at a time and plan on installing them all at the same time. Future mods soon to come on the car are BMR adj LCA's, BMR solid UCR and brace, BMR panhard bar brace, and larger sway bar. For right now from what I've read on here it seems like the stock strut mounts in front are a one time only thing and should be replaced when worked on? So I plan on upgrading this as well and have been looking at the Maximun Motorsports strut mount/camber plates. They seem to be a high quality piece and would like to hear from anyone that is running them and how they like them. Other opinions on this subject are appreciated as well as I'm open to any ideas.
Old Apr 16, 2008 | 09:07 AM
Argonaut's Avatar
Argonaut
Default RE: strut mount recomendations
I installed the J&M Camber plates, primarily because of this writeup: http://www.stangnet.com/Tech-Article...ll-070511.html
You will probably get a few responses saying the *only* plates to get are the Steeda's. Everyone has there opinion but thus far the J&Ms have performed perfectly for me.
I have been told by some very knowledgeable folks that you do not need Caster adjustment in these cars, the factory setting is good. Thus the MM double adjustables are probably overkill.
I've also read that Ford has done a couple redesigns of the OEM strut mounts and the latest ones do not have the popping noises of the past. In other words, you don't need to get adjustable plates to solve the clicking/popping noise problem - OEM mounts and camber bolts would be a cheaper option unless you really want the plates.
Old Apr 16, 2008 | 11:55 AM
ChiDiddy's Avatar
ChiDiddy
get the plates, do it once, do it right. you dont know if u're going to need to take it apart again. if OEM, it might not be able to be reused. Camber bolts are only a bandaid to a wound that needs stitches. Plates are the solution.
Old Apr 17, 2008 | 06:33 PM
lindseyquads's Avatar
lindseyquads
ORIGINAL: ChiDiddy
++++1....very well said
Old Apr 17, 2008 | 08:43 PM
JTE_502's Avatar
JTE_502
ORIGINAL: ChiDiddy
That was the plan Just wanting opinions on the different plates that are out there. The different brands of them vary quite a bit. If the ones made by MM are overkill and I don't need the double adjustment of them I can save $100 with a different brand. Which plates are you running ChiDaddy?
Old Apr 17, 2008 | 09:53 PM
Stoenr's Avatar
Stoenr
Dunno about a band-aid. We use them all the time in the shop without issues. All makes all models.
Old Apr 17, 2008 | 10:09 PM
lindseyquads
I am running the Steeda HD plates. Very nice quallity I'm happy with them but dont think you can go wrong with any of the known brands all depends how much you want to spend.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
