Roush Suspension Kit Questions
Old May 3, 2008 | 08:28 AM
shelby69's Avatar
shelby69
Default Roush Suspension Kit Questions
I am thinking about buying a the Roush Suspension kit (not the track pack one). I am wondering if anyone has it on their car and if you like it. Also, it lowers only one inch. Do I need an adjustable panhard bar, bump steer kit, and/or camber/caster kits? Or is it a bolt on and go. I am not planning on doing any racing, other then an occational autocross. Looking to lower it a bit and increase the cornering a little.I miss the handling of the Audi S4 I had before. Also, my car is a stock GT convertible.
I do not want to piece out all the suspension stuff seperately. I would prefer a kit and have always had good luck with Roush stuff even though its not the cheapest.
Thanks for the help.
Old May 13, 2008 | 02:52 AM
F1Fan's Avatar
F1Fan
Default RE: Roush Suspension Kit Questions
ORIGINAL: shelby69
Hi shelby69,
Pass on the Roush S197 suspension you can easily do better on your own or by following one of my simple recipies for S197 handling success. First off you need to relaize that with a convertable you have a chassis that will never be an effectiveplatform for a truely high-performance suspension and that what you should buy and installfor your car largely depends on what you want to do with your car, where you live, what your roads are like etc. Your S197is not very stiff with the roof cut offso one of the best things you can do is toimprove your chassis stiffness. To do this you need an effective strut tie bar (Agent 47 is theonly decent STB on the market)and a set of the stiffest subframe connectors welded into the chassiswhichare BMR'srectangle tubed heavy duty subframe braces. You will need to modify the BMR brace slightly due to the verts rear braces but the shop welding them inwill see the changesneeded.Then adda moderate rate Sport spring with a moderate ride height andadjustable dampers (D-Specs will work better in this application)and improve your rear axle location with an adjustable Panard bar and HD Panhard bar brace and a set of GT500 LCA's. then just install a good set of performance tires and do the usual brake upgrades (pads, racing fluid,S.S. brakelines, brake cooling ducts) and stop right here, you are done as the vert's chassis is the limiting factor. If you had a coupe that S4 would be looking at your tail lights as you pulled away from him in the twisty bits. Settle for keeping him in sight and enjoy the sunshine.
HTH!
Tivo304
Aug 28, 2023 12:19 PM
musnicki
Sep 23, 2015 07:11 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
