quick LCA question
Old Jun 19, 2008 | 05:57 PM
sweetlou69's Avatar
sweetlou69
Default quick LCA question
im looking at some LCAS, 99% street drivin with a few passes at the 1/4 mile. i was lookin at the steeda non adjustables from brenspeed for 199$. Will those do the trick or should i go adjustable? And if i do go with the 199$ lcas do i need anything else?
Old Jun 19, 2008 | 08:57 PM
sweetlou69's Avatar
sweetlou69
Default RE: quick LCA question
actually forget that last post, ive decided im going to go with the steeda billet lcas. i noticedthere not adjustable, should i go with adjustable? or will they be ok
Old Jun 19, 2008 | 09:27 PM
wicked stang's Avatar
wicked stang
you only need adjustable LCAif your lowered to adjust pinion angle, but that can be taken care of later with adj UCA if your not lowered but want to in the future.
Old Jun 19, 2008 | 09:38 PM
sweetlou69's Avatar
sweetlou69
i will be lowered in about a week, just a 1" drop. so in that case i should go adjustable then huh?
Old Jun 19, 2008 | 11:46 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
one inch drop you should be fine.
Old Jun 20, 2008 | 12:30 AM
F1Fan's Avatar
F1Fan
ORIGINAL: sweetlou69
Hi sweetlou69,
For a street car you don't need adjustable LCA's or an adjustable UCA. If you are going to lower the car 1" and want to keep a decent ride and improve your wheel hop and launch grip a good setup is a pair of FRPP GT500 LCA's and a Steeda tubular UCA. The GT500 LCA's are cheap and effective and will cause you no pain to install ot maintain and are easy to replace down the road. The Steeda tubular UCA is slightly shorter and designed to work oncars lowered 1" like the springs they sell but will also work fine on a car at stock ride height. The later tubular LCA's from Steeda are usnig a 3-piece poly bushing which improves artifical spring rate issues due to the inherent bind of all constrainedpoly bushings. This setup will run you about $30 more than your $200 LCA's and give you a more effectively located rear axle.
HTH!
tmdm
May 2, 2021 02:49 PM
Oct 7, 2015 07:02 PM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
