Good Vibrations (Not really)
Old Jul 26, 2008 | 05:02 AM
MuchToLearn's Avatar
MuchToLearn
Default Good Vibrations (Not really)
Alright...so when I am at speeds of anything around under 40-50 MPH, everything is fine. However recently, when I've exceeded 50 MPH, my steering wheel starts to shake or vibrate a bit. I don't think it is my exhaust or anything like that...I hit a curb not too long ago and shortly after that I noticed this happening. I wasn't going too fast, but It did happen. Curb was on the right side. Could I have knocked something out of alignment or messed something up?
How could I check??
Thanks
Old Jul 26, 2008 | 07:17 AM
Norm Peterson's Avatar
Norm Peterson
Default RE: Good Vibrations (Not really)
If you can set up a pair of parallel strings (one down each side of the car) you can check toe, which is probably out of spec. Problem is, you´ve probably bent something like either the spindle (that´s just the stub axle, BTW) or the knuckle. Check also for a bent wheel and look for places where a wheel weight might have been fastened (but got thrown off by the impact).
Norm
Old Jul 26, 2008 | 09:15 AM
timothyrw's Avatar
timothyrw
this didn't start after you got new wheels or rotated your wheels did it?
https://mustangforums.com/m_5316601/tm.htm
if you curbed your wheel you also may have lost a wheel weight.
Old Jul 26, 2008 | 09:54 AM
lrgnation's Avatar
lrgnation
at 45+ its your wheels. You need them balanced.
Old Jul 26, 2008 | 02:12 PM
MuchToLearn
No, these are not new wheels or anything like that.
Old Jul 26, 2008 | 08:45 PM
MuchToLearn
If I bent the the wheels somewhere...would It have messed up just the rims themselves, or would it have possibly thrown something else out of whack? I wanted to get new rims eventually... If I got new rims, would that fix the problem if it were just bent rims? Or is there something else causing it like the entire thing got thrown out of alignment?
I really dont know what I'm talking about here.... so sorry if everything is vague lol.
Old Jul 26, 2008 | 09:51 PM
Sleeper_08's Avatar
Sleeper_08
If your tires are not directional you could swap the wheels left to right and vice versa to see if the vibrations followthe wheel.
Old Jul 27, 2008 | 06:44 AM
Norm Peterson
Just for the duration of testing, running directional tires on the "wrong" side is not a problem. Or you could swap tires front to rear if they´re the same size (or at least close).
Norm
Old Jul 27, 2008 | 04:18 PM
MuchToLearn
But...If I switch them...I'll still have the vibration either way...
Old Jul 27, 2008 | 05:47 PM
Norm Peterson
What you´re trying to do is determine if it´s a bent wheel or a bent suspension part by whether the vibration moves to the corner that you move the wheel to or not. That might help tell you where you need to start.
Norm
mtgldr
Feb 3, 2024 09:00 PM
bjdutch2005
Mar 24, 2017 03:38 AM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
Sparks_88
Sep 8, 2015 01:06 PM
