PDX Tire Pressures
Old Aug 7, 2008 | 09:56 AM
2007GT/CS's Avatar
2007GT/CS
Default PDX Tire Pressures
Recommendations for initial set up? BFG KDW 275/35/R18 on all 4 corners.
Going up to Mid Ohio tomorrow
Old Aug 7, 2008 | 05:56 PM
Sleeper_08's Avatar
Sleeper_08
Default RE: PDX Tire Pressures
Running285/40/18 KDW2s on 9.5 inch rims we were running 40 psi this past weekend on a 1.3 mile flat road course. We ended at 40 psiafter checking the temp readings with a pyrometer.
The only problem we were getting was scuffing on theoutside shoulder of the left front and this was probably due to a long right hand sweeper. Camber is - 3/4 degree with 1/16 toe in. Putting more camber on would probably have helped with the scuffing. Time to rotate front to back.
Hope you have fun. I had a blast - chased down a hopped up SRT8 and he was just pulling me a bit on the straights - not what he expected. Caught up to him in the corners.
Old Aug 7, 2008 | 06:49 PM
2007GT/CS's Avatar
2007GT/CS
Saweet!
Thanks for the 411. We'll give that a shot.
I understand Mid Ohio has about a 3500 ft. back straight (well, with a slight dogleg). 'Technical' track with a lot of elevation changes and some interesting turn cambers.
I'll file a report when I get back .
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
marc954
Sep 29, 2015 11:18 AM
