Unusual? tire wear
Old Aug 10, 2008 | 09:33 PM
houstonnw's Avatar
houstonnw
Default Unusual? tire wear
I have a 2007 GT with stock springs, 1.8 negative camber, and 36 psi hot.
After my last track day at TWS Clockwise, this is what my left front tire looks weird.
What possible alignment or tire pressure setting could possibly wear that second groove like that?
(I give up, I can't link or attach or whatever, so I started a new thread here)
http://forums.corral.net/forums/show....php?t=1045753
Old Aug 11, 2008 | 06:22 AM
Norm Peterson's Avatar
Norm Peterson
Default RE: Unusual? tire wear
Have you tried uploading it as a thumbnail? There are filesize restrictions, and you will get a big red "X". However, clicking on the "X" will bring up the pic.
Second-rib Wear
Second-rib wear is normally found only in radial tires, and appears where the steel belts end in relation to the tread. Normally, it can be kept to a minimum by paying careful attention to tire pressure and frequently rotating the tires. Some car and tire manufacturers consider a slight amount of wear at the second rib of a radial tire normal, but that excessive amounts of wear indicate that the tires are too wide for the wheels. Be careful when having oversize tires installed on narrow wheels.
[IMG]local://upfiles/62186/5639F9B063154DDB86B98C6E57714F8C.gif[/IMG]
Linky.
This sort of wear was fairly common I think with the early belted-bias tires, particularly in the (for then) low profiles.
Norm
Old Aug 11, 2008 | 06:35 AM
Norm Peterson
ORIGINAL: Norm Peterson
ORIGINAL: Linky.
Second-rib Wear
Norm
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
