Rotor Pros High Performance Pads
Old Aug 21, 2008 | 10:24 PM
rshamekh's Avatar
rshamekh
Default Rotor Pros High Performance Pads
Hey everyone,
I emailed Rotorpros earlier today for a quote on their
drilled/slotted rotors.
I got a reply with a pretty good price, and they offered
high performance brake pads with it for an additional $75.
If anyone have tried those pads specifically, how good are they?
And how would you rate rotor pros drilled/slotted rotors in general?
Old Aug 22, 2008 | 10:15 AM
GotMunchies?'s Avatar
GotMunchies?
Depending on application - I would not buy any rotor that had been drilled. If you plan using your brakes in any kind of performance environment do not get cross drilled rotors - the holes act as stress concentrators and facilitate cracking in the rotor surface. As a street or show car, this would not be an issue. However, if you plan on stopping hard, do not get drilled rotors. Slotted rotors are great for performance applications - the grooves work to remove the build up of gases built up between the pad and rotor because of rubbing, facilitate the removal of water, aid cooling in a very minor way, and do not significantly weaken the rotor structure.
And this kind of answers your question about the brake pads - if you want the brakes for the looks, then don't worry about the pads. If you want them for performance, then get the pads. I haven't heard anything about them, use the search function to see if anyone has posted about them in the past.
Old Aug 22, 2008 | 12:28 PM
rshamekh's Avatar
rshamekh
Thanks for your input.
I don't plan on doing any performance driving.
It's mainly a DD street driven.
So, I understand that the drilled rotors could
crack under hard braking.
I just want to change out the pads since I'm
changing the rotors, but was wondering if
I should go with their pads or get some Hawk
pads instead?
mungodrums
Suspension
May 16, 2019 09:36 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Wombatnation
Sep 13, 2015 09:16 PM
Sep 8, 2015 11:50 AM
