Bought a pyrometer today
Old Oct 22, 2008 | 08:08 PM
jayel579's Avatar
jayel579
http://www.toyo.com/docs/tires/tires...&category=comp
Jazzer-
You should be starting your tires are 35 psi that is about what Toyo recommends. If you are unsure of the tires being under or over inflated you can check the side walls after a run. On the shoulder of the tire is a little arrow or triangle. You should be rolling over your tires to that point on your runs. If you are rolling past your under inflated, if you aren't reaching the arrow you're over inflated.
The R888 is more of a road race tire so they will like more heat in them then your typical autocross tire. I don't think you will over heat them on the autocross track.
Jb145700
Aug 21, 2022 06:37 AM
Oct 7, 2015 07:02 PM
LivingInThePast
Sep 16, 2015 12:20 PM
Luke9222
Sep 4, 2015 06:46 AM
