wheel help
Old Dec 14, 2008 | 10:58 PM
legendlime05's Avatar
legendlime05
Default wheel help
would an offset of +10 be like on my car? just curiosity i guess
Old Dec 14, 2008 | 11:13 PM
UrS4's Avatar
UrS4
Bad!
Stock is 45mm, so your wheel would stick out 35mm further. Thats 1.5 inches further out. When I measured the distance from the sidewall of the tire to being flush with the outside edge of the wheel well, it was 1-1.25 inches. But remember, if the rim you are looking at is wider and has that 10mm offset, it will stick out further still. Find a wheel calculator online to help show you what the change will be.
Old Dec 14, 2008 | 11:42 PM
Texotic's Avatar
Texotic
depends on if the wheel is the same width as the stock ones, then yeah, it would look horrible.
Old Dec 15, 2008 | 08:03 AM
jdmcbride's Avatar
jdmcbride
Horrible!
Old Dec 15, 2008 | 09:10 AM
jayel579's Avatar
jayel579
Originally Posted by UrS4
Stock is 45mm
45 mm on the 17x8 wheels, it is 50 mm offset on the 18x8.5 wheels.
Old Dec 15, 2008 | 11:17 AM
Texotic's Avatar
Texotic
mine are 18x9 with a 36mm offset and they are perfect. I don't think any size will look right with a 10mm offset...
Old Dec 15, 2008 | 11:50 AM
Nuke's Avatar
Nuke
PM me with your e-mail. I'll forward a spreadsheet for plugging in tire sizes and offsets.
Old Dec 25, 2008 | 10:39 AM
Poco's Avatar
Poco
I've seen some run less offset that on s-197's and it is darn right stupid looking. Hit a water covered pot hole and slice a good tire not to mention body damage that could cost you big time. There are some deep dish wheels that not only fit correctly but look very retro. Many s-197 owners have run the new AR Razors with a 24mm offset and fits pretty good.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
