20 back and 18 front
You will begin to introduce issues with the ABS system if you start getting too much differential between front/rear tire diameters. I don't know how much you can have without issues, but some figure as little as +/- 5%.
Why do you want to do this?
Jazzer
Jazzer
That may cause some understeer issues. If you match up overall diameters your 18's will have more sidewall than your 20's and look rather odd.
I ran a staggered set of 18" DD Bullitts and the rear tire had a much larger overall diameter and it drove pretty smooth.The car is lowered and with the staggered set up the rake came back but the huge gap was filled in nicely with the larger rear tires.I had no issues with the ABS system but I did have minimal understeer.
Because if you make the tires the same diameter on different size rims, it looks stupid. The 350/370Z's ABS system is engineered to have the larger wheels out back, so it's a non-issue. We don't have that luxury, unless you think you have to know-how to reprogram the ABS system within the car's ECU.
YoungStangsMan
09-05-2015 07:01 PM
