Problem with new wheels?
Old Mar 6, 2009 | 09:10 PM
mpatilla's Avatar
mpatilla
Default Problem with new wheels?
I put new 17 bullitt rims on my V6 today. I was getting a clicking noise, maybe almost metallic sounding from the left rear. Is it possible that the wheels are hitting the caliper? It seems like there isn't much clearance there.
Thanks for your help!
Old Mar 6, 2009 | 09:47 PM
Texotic's Avatar
Texotic
Not if you have stock calipers... I'm assuming you're talking about OEM 17" Bullitt rims.
Old Mar 6, 2009 | 09:52 PM
mpatilla's Avatar
mpatilla
Yes, they are takeoffs from a GT. New tires too, might just have been a piece of gravel or something in the treads. It just seemed to have more of a metallic sound than that.
Old Mar 6, 2009 | 09:56 PM
Texotic's Avatar
Texotic
Yeah, there's no way they're hitting the caliper unless something is REALLY messed up. I know some people have had problems with putting on aftermarket wheels because of some rotor retainer clips that got left on some of the cars after they left the factory, but that wouldn't affect a takeoff rim, I wouldn't think. You'll have to wait for some other people to weigh in their opinions because I don't know what it could be.
Old Mar 6, 2009 | 10:02 PM
.boB's Avatar
.boB
I had the same problem with an older Ford. A distinct metallic clicking noise. Heard best at slow speed. Seemed to go away at higher speeds.
Turned out it was a loose wheel weight sliding back and forth as the wheel turned.
Old Mar 6, 2009 | 10:09 PM
mpatilla's Avatar
mpatilla
Hmm... that would definitely make the kind of sound I'm hearing. I'll take a look at that.
Old Mar 7, 2009 | 08:14 AM
NJ3's Avatar
NJ3
It's possible you picked up a rock, screw or nail already. They will all make a metallic clicking noise.
Old Mar 7, 2009 | 11:27 AM
UrS4's Avatar
UrS4
Did you take off the Ford retaining washers that are on 1 or more of the stock lug bolts? When you put a second set of rims they are not on correctly and may cause a noise.
Old Mar 7, 2009 | 12:25 PM
mpatilla's Avatar
mpatilla
Thanks to all of you for the responses. I did take out the retaining clips. This morning I got out on the road and it was making the noise. I stopped and pulled out a pretty good sized rock that was apparently on the underside of the tire when I looked last night. That did the trick. I was surpised that the rock made that much noise.
Old Mar 7, 2009 | 01:48 PM
157dB's Avatar
157dB
Cut & Paste Expert
The rims will clear the rear calipers with space to spare.
Its probably a rock.
Jack up her rear and rotate the rear wheels by hand while inspecting
the tread for rocks or other foreign objects.
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
NorthAmericanTuning
Nov 9, 2016 11:44 AM
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
