Install Question: LCAs first or Rear Springs first?
Old Mar 7, 2009 | 08:41 AM
dan_h's Avatar
dan_h
Default Install Question: LCAs first or Rear Springs first?
For those who have done this already...i'm installing (both at the same time) Roush Rear Springs along with J&M Fixed Length LCAs in the near future on my 2006 GT. Does it matter which I install first? Is it better and/or easier to install the LCAs before the springs?
Thanks in advance for the help,
Dan
Old Mar 7, 2009 | 02:31 PM
Stoenr's Avatar
Stoenr
If I recall it should not matter. Doing the springs I believe was unbolting the lower shock, letting the axle drop some, swap out the springs, raise the axle back up, bolt the shocks back in.
Its been a while, so im not 100% sure. But someone here will.
Old Mar 7, 2009 | 04:05 PM
157dB's Avatar
157dB
Cut & Paste Expert
Be sure and tighten all hardware back to factory torque specs and with the
vehicle at ride height, not rear end hanging on jack stands supporting the body.
Old Mar 7, 2009 | 05:14 PM
Sleeper_08's Avatar
Sleeper_08
Blue Loctite is also a good idea.
Old Mar 7, 2009 | 06:01 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
doesn't matter which you do first and the LCA's i believe should be torqued to 129 ft/lbs!
How to for springs
https://mustangforums.com/forum/2005...ll-w-pics.html
and one for the LCA's
https://mustangforums.com/forum/2005...s.html#4370038
all the same principles apply and same with the tq specs!
drfister
May 3, 2018 10:38 PM
Urambo Tauro
Dec 17, 2016 03:30 PM
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
WDScott
Aug 17, 2015 06:38 AM
