Lets Talk Brakes
Old Jun 19, 2010 | 11:16 PM
  #111
steelcomp's Avatar
steelcomp
double post...sorry.
Old Jun 19, 2010 | 11:25 PM
  #112
steelcomp's Avatar
steelcomp
First I've heard of the wiggle as a "stick axle" trait...not saying it doesn't have something to do with it, but I do know I can bring my car down as hard as I want, and although I've never tried it, I could probably take my hands off the wheel. OK...LOL...not literally, but you get my point.
I'm running a few mods that aren't so typical, like the front A arm relocate kit, the A arm rear bushing supports (black ones), GT500 front LCA's and 385# springs (or 430's on the track.) The double adjustable Koni's help, too.
I went for a ride in a Cobra (replica) once at Willow (big track). When the guy hit the brakes for turn 1 at the end of the straight, I didn't think he was going to be able to control the car the "wiggle" was so bad. Flat scared the crap out of me as a passenger.
On the Mustang, I wonder if the A arm rear bushing supports might help. Those rear "hydrabushings" are awfully soft. That can't be helping under hard braking, especially wirh R Comps.
Old Jun 19, 2010 | 11:42 PM
  #113
steelcomp's Avatar
steelcomp
Originally Posted by Argonaut
John - when I was tracking my Stang with stock brakes +standard upgrades, Hawk HT-10 and NT01s I did get some of the 'wiggle' you describe. I remember distinctly the car doing this. In fact, I remember at VIR, heading into Oak Tree, hitting the brakes hard and the wiggle was enough for my instructor to comment on it. It was his opinion that its a common trait of stick axle cars. Another data point - just recently on another forum a guy who traked his stick axle F-body was complaining of the same thing. For me it was never all that bad though so I'm guessing yours is much worse.
Ever hear of Jay Andrews? He is a former NASA Nat Champ in American Iron, drives an older stang or at least he did last time I followed that series). He is also a Hawk dealer and brake expert - he frequently is sought after to give clinics on brake tech. Really nice guy, you may want to call him and discuss it. http://www.andrew-racing.com/
Regarding rear pads - the biggest reason 'common wisdom' says to use less pad in the rear is not due to the agressiveness or friction but rather due to the temperatures. Rear brakes have lower temps and therefore need pads whose sweet spot occurs at a lower temp than the fronts. At least for normal brake systems thats the way it works. For the S197 system....not sure, I've heard so many confusing things about the brakes on this car its hard to tell what true and whats not.
Which StopTechs do you have - ST40? Is it the kit made specifically for the S197 Mustang? I'm sure you know this but for those folks who don't - vendors like ST make the same caliper with different bore sizes for different cars. Its not a one size fits all kind of deal. When swapping fronts from a 2 piston, 13" brake to a 4 or 6 piston, 14" brake and keeping the OEM rears its very important to keep the front and rear brake bias the same or nearly the same. A high quality vendor like StopTech does this by sizing the pistons. So...the ST40 caliper for say a STI will not work properly on a Mustang. Some vendors don't do this and a lot guys don't know this and then they end up wondering why the sexy red BBK they bought on flea bay doesn't stop as well as their old OEM setup.
The rear brakes on these cars see way more use than typical rears. My very first time to the track, I completely destroyed my rear brakes. Took them right down to the metal backing plates and ruined the rotors. Stock brakes with a pad upgrade in front. Subsequently, I learned that the rears see quite a bit of load through the biasing because of the anti lock system. The anti lock computer monitors all four wheels independently. I also know they don't cool very well, and will get quite hot.
You made my earlier point about the anti lock calibration and changing calipers. ST is the only company I know of that talks about calibrating their calipers to match the anti lock's computations. My 6 piston Wilwoods seem to work very well as I almost never get into the antilocks. I was on an on ramp once, just getting up to speed, probably about 50mph...look in my mirror, look back ahead of me and holy crap! The girl in front of me had slammed on her brakes at that very same instant. All I saw was the back of her car lift about 8" and I thought I was screwed, and prepared for impact. I had less than 20' and all I could do was plant my foot on the brake as hard as I could and I'll be damned if I didn't hit her (came within inches). The anti locks worked absolutely perfectly and modulated about three times just before what would have been certain impact. I've since wanted to do a braking distance test with the car, just never got around to it.
Old Jun 28, 2010 | 11:14 PM
  #114
Lil_Chef's Avatar
Lil_Chef
im actually ordering a BBK on my car sometime this week and i am concerned about how the kit will work with ABS and the Front/rear bias. Would you guys rank Baer high on the list of reputable brake companies? i am considering either their Pro Plus kit, or just going with the steeda bbk.
Old Jun 29, 2010 | 08:32 PM
  #115
Argonaut's Avatar
Argonaut
My 2 cents:
I dont' know much about Baer because I don't know and haven't even heard of any amateur road racers using them. Not saying they are bad but they certainly aren't popular in my neck of the woods.
Someone correct me if I'm wrong but the Steeda's look like rebadged StopTech ST40s. If so, they are an excellent choice.
Old Jun 29, 2010 | 09:07 PM
  #116
steelcomp's Avatar
steelcomp
X2 on the Baer's. Don't know a single person running them. I've been very happy with the Wilwoods.
Old Jun 30, 2010 | 01:29 PM
  #117
Lil_Chef's Avatar
Lil_Chef
i guess ill be the guinea pig for the baer kit then !
and you are correct the steeda kit is just a rebadged stoptech kit.
Old Jul 9, 2010 | 01:36 PM
  #118
Lil_Chef's Avatar
Lil_Chef
just got my baer pro plus kit in today. im not sure how much the stock parts weigh but the rotors weigh 18 lb each and the calipers (w/ pads) weigh 8 lb each. i should be installing the kit sometime next weekend as im going out of town this weekend. im excited, these things look good.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
breaking
Oct 2, 2015 01:27 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
