I have the exact same LCA's and brackets. Right now the brackets are bolted in, but I think they reccomend welding in after 400hp, I will do that if i can find someone that weld around here. Good luck
LCA Relocation brackets should always be welded in, IMO. I'll be getting Steeda's welded in eventually.
Sorry about the delay in getting back to you. Yes i would weld in the relocatiopn brackets. I would recommend it anytime relocation brackets are installed.
