Front Strut Bearings
Old Apr 10, 2009 | 09:45 PM
VWILLO's Avatar
VWILLO
Default Front Strut Bearings
Where are they, parts breakdown?
Old Apr 11, 2009 | 09:27 PM
shoe48's Avatar
shoe48
The Bearing are in the upper strut mounts , you usually repalce the Stuts upper mounts as a whole , Ford Racing has them at around 60.00 a pair
Old Apr 15, 2009 | 08:02 AM
Ato's Avatar
Ato
I didn't have any trouble reusing my stock strut mounts, as long as the bearings stay in the race you should be ok. I also didn't lower the front of my car so that can have something to do with it.
Old Apr 15, 2009 | 01:25 PM
BMRFabricationSales's Avatar
BMRFabricationSales
Former Sponsor
Hello, the upper strut mounts are located on the underside of the strut tower. The four studs that are sticking up belong to the upper mounts. When you change springs or struts you have to take these off and most of the time the little ball bearings that are inside fall out. Some times you can get lucky and not lose any and if tis is the case you do not need to replace the mounts. Ford has two different models, one for a coupe the other a convertible. Give me a call if you have any questions.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
marc954
Sep 29, 2015 11:18 AM
