Rear Shock Install
You don't need a lot of height, since you only need to get at one bolt per side. Since you'll be exerting quite a bit of force to loosen/retorque the axle side shock bolts, this is a job that you should absolutely never be doing with a jack, and I'm not all that comfortable with jackstands here either. I'd drive one side at a time up onto a curb and lay down in the gutter to work first.
If you don't have/can't get hold of a set of ramps, it's easy enough and cheap enough to nail some lengths of 2 x 10 lumber together and make your own. Different lengths will let you approximate the 'ramp' enough to drive up onto even if you don't miter the ends. Nail a 'stop block' to keep you from driving past the end.
Norm
Norm
I actually jacked the entire thing up and set it on jack stands. Then I jacked up the rear end, so my springs didn't shift while I was trying to get the shocks off. If you check the rear spring install thread, under the "V6 Handling" topics, I basically followed that. I now have a brand new FRPP rear sway bar that I can't use though. Since I have no hardware.
OK at the end everything was very easy. It took me about 1 hour, but I was in no rush. Jacked up one wheel at a time. Used a small bottlejack under the center of the differential with a piece of 2x4 in beetween. It was useful for supporting the rear axle and aligning things for the lower bolt. The only question I had was how right should the upper small nut be? It seems to compress the rubber bushings but how much is enough or too much? I guess guessed this part... Anyways, with the new Tokico HP the rear seems to ride just a bit softer and quiter, but may be its just my imagination.
Bushings should be compressed enough to be just barely beginning to develop a convex shape. I apologize for the crudeness of the following ASCII sketches.
(______) about right, maybe a little too little
(______) is a little too much
(______) is way too much
Norm
Norm
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
