Noob question: Will sway bars alone make a big difference?
To each his own... The last set of Eibach damper I was on (with Eibach springs) was a disaster. FWIW dampers are not easy to make well, and I prefer those with knowledge, experience and understanding to do it. I prefer Koni's in most cases, which is why I have them on my car. FWIW, I don't feel Eibach's springs are even close to the best. Ok, but the last few years there has been a pattern of lacking rate to support the drop (also not exactly accurate claimed drops).
Fixed - A couple of good threads about dampers
https://mustangforums.com/forum/s197...5-mustang.html
https://mustangforums.com/forum/s197...nis-again.html
I installed the Eibach anti-roll kit without changing springs or shocks. I had low expectations on the kit as I figured I would just install the swaybars first and the later lower the car and install some dampers; money permitting.
The sway kit did it for me. When I first drove out of the shop and did a few swerves, I really felt a difference (I did a few swerves right before arriving to the shop). The handling improved enough for me to forget about lowering the car just yet. I may lower "for looks" later on after the stock shocks are shot to pieces and the warranty is over, but for now, it handles good enough for me. No more wallowing of the front tires when taking a sharp turn on a shopping mall's multifloor parking.
They're easily replacable on jackstands like every other supsension component on these cars. The most trouble I had was swapping the UCA but once you swap a part the first time you can do it in half the time (or less) the next. I just retorqued every part on my suspension in about an hour earlier this week...
As far as stick-axle Mustangs are concerned (most all stick-axle cars of any make/model, actually), the rear suspension on the S197 is a huge step up from that used in any of the previous cars. The front suspension is at the very least no worse, and the chassis itself is more rigid. It's better to get your basic geometry closer to right than it is to have to band-aid poor geometry and a limber chassis with excessively stiff springs/bars/dampers.
The detail selection of things like springs, bars, and damping curves is a separate issue with no single set of choices ever being likely to please everybody.
Norm
Norm
