Lowering Springs Install
In case you haven't seen it yet Taco Bill has posts on both the front and rear spring install
http://forums.themustangsource.com/s...d.php?t=441678
If my memory is correct you need a deep 18 MM socket for some bolts.
Use blue Loctite on assembly and double check all of your torque settings.
If you are going to track the car give consideration to replacing the spindle to strut bolts with the new fine thread ones
https://mustangforums.com/forum/s197...elfection.html
