Springs VS Sway Bars for Handling Gains?
Since we are on the topic of sway bars, I'm wondering if that is what I now need.
This past summer I added a whipple supercharger & in the process about 120 pounds to the front of the car. This is a difference I can definately feel. I went from a 53/47 balance to 55/45. The car wants to keep going straight more than ever; and the front end of the car feels like it rolls more relative to the rear. I stiffened the front struts a bit, but I also need to maintain reasonable ride quality (I drive on terrible roads).
I never planned to touch the sway bars, but I don't like how the car handles at the moment, it's starting to remind me of how my 94 Probe GT handles.
Is a rear bar the answer? Or maybe both?
Edit: My weight balance is probably worse than 55/45. I reduced the weight in the rear by chaning the stock axle back out and I don't keep the spare in the trunk.
Also with a set of bars that is adjustable at both ends (most aren't) you can tune the balance to your liking. Want more rear roll stiffness? You can do it. Want more in front? You can do it. Want more at both ends, but more at one end? You can do that too. That's the beauty of adjustable bars are both ends, you get yourself 3 settings at each end to set as needed.
Bottom line you added weight to the nose, that's weight that is up high. I don't think you need or want the front bar full stiff--but you can use a little help there, and then some from the rear on balance (which is needed anyway, even before).
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
