Looking for forged wheels
Old Mar 19, 2010 | 10:37 PM
Riptide's Avatar
Riptide
Running a 285/40/18 in the rear. Not sure how much if any wider I could go with a 9.5.
Old Mar 19, 2010 | 11:49 PM
peetiewonder's Avatar
peetiewonder
rays are solid wheels. With the right offset you could rock as big as like a 10.5 or 11 in the rear. I'm rocking 9.5s in the rear with 275s and I have 15mm ~.5" to work with on the front side and no clue how much clearance i have on the inside.
Old Mar 20, 2010 | 04:45 PM
baddog671's Avatar
baddog671
I currently looking at 295/45/18 Nitto555 tires. The tire specs say it will work on a 9.5 rim, but no smaller. Another member has these on his stang and has it also lowered, so I don't think there would be any rubbing issues. Considering Riptide is ok with his setup, I suppose mine would be no more troublesome (if I decided on the RPF1's).
I just wish those damn Axis wheels had different sizes!
Old Mar 21, 2010 | 02:45 PM
candymanjl's Avatar
candymanjl
that's a 1.25" taller tire than the stock diameter, just something to keep in mind.
I'm going to run a 305-35-18 rear when I get my setup, that's just a touch smaller than stock and will match the 275-40-18 front I'll be running perfectly.
Old Mar 22, 2010 | 11:06 AM
Riptide's Avatar
Riptide
A 295/45/18 is a huge tire. Not only is it 28.5" tall but keep in mind that adds extra weight vs. say a 285/40/18. Sure it's only 2-3 pounds but that's still rotating mass and multiply it 4x.
I had 295/45/18. Two positives. Good traction, lots of contact patch and sidewall. And it also filled out the fenderwell in the back equal to the stock.
But it killed some of the torque the car had, added weight, and raised the rear end further off the ground.
I got rid of mine.
Old Mar 22, 2010 | 12:31 PM
baddog671's Avatar
baddog671
Dammit, now you have me doubting myself and I'll have to investigate other options
Old Mar 22, 2010 | 11:09 PM
Kona6Stang10's Avatar
Kona6Stang10
ccwheel.com
Old Mar 24, 2010 | 02:42 AM
mblgjr's Avatar
mblgjr
Steve is great do deal with.
Also has some special recession-buster pricing going on
www.trueforgedwheels.com
info@trueforgedwheels.com
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
