New wheels, but alignment is off
Old May 5, 2010 | 10:49 AM
Norm Peterson's Avatar
Norm Peterson
Dunno.
±3° adjustment means that more metal has been removed in order to let the nose of the "cam" portion stand up higher to get that extra adjustment. IOW, it may not be quite as strong as a full cross section bolt, and may not permit the same torque setting.
They're probably OK on a daily driver or weekend car that isn't normally driven very hard, or even on a car that sees an occasional drag race.
But I would never consider running them on a car driven in autocross or open-track road course events or one that regularly sees frequent hard cornering and hard braking. Not even brief consideration.
Norm
Old May 5, 2010 | 02:54 PM
Sleeper_08's Avatar
Sleeper_08
Originally Posted by Norm Peterson
Dunno.
Norm
+1 - especially as Ford did a running production change and upgraded the stock bolts from a course to fine thread to allow for a higher torque setting.
Old May 5, 2010 | 06:19 PM
6-Speed's Avatar
6-Speed
My stock strut/spindle bolts, two of them per side, are torqued to 148 lb-ft each. The new fine thread bolts, I understand are torqued to 166 lb-ft. Obviously Ford thought it was important to go up in clamping force provided by these fasteners. The camber bolts I've seen are only torqued to 77 lb-ft and replaces one of the strut/spindle bolts on each side; that's only 52% of 148 lb-ft and 46% of 166 lb-ft.
I'm not going to compromise on one of two bolts that secure the spindle regardless of how I drive my car.
Old May 5, 2010 | 06:46 PM
Sleeper_08's Avatar
Sleeper_08
Your torque setting are correct and I agree with you.
There is a thread showing what happens when these bolts get loose but I can't find it right now. Broken spindles are not pretty.
winner99
Sep 30, 2015 07:04 PM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
mungodrums
Sep 28, 2015 10:54 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
