Which LCA to get for my 2007 GT
I understand the reasons for getting LCA's with spherical ends, but I'm still leaning towards the ones with poly bushings.
Do the Spherical parts have a shorter lifespan/higher maintenance?
I just don't want to get one set of LCA's then decide that I should have bought the other. That's why I asking so many questions.
I understand.
Unlike a lot of places that just want to sell parts, I also want to sell you the best part to fit your needs.
Any will help your wheelhop, but something that articulates will work better over imperfect roads.
I'd suggest either of these two for that reason:
http://www.stranoparts.com/partdetai...D=99&ModelID=5
or
The UMI roto-joint is fully serviceable and tensionable which a rod-end or normal spherical bearing is not..... I'd really recommend that UMI part, and if you need adjustable they make the same thing in adjustable as well. In fact, here's the entire LCA page from my site: http://www.stranoparts.com/searchbym...&CategoryID=99
or
Seanam
10-04-2015 10:15 AM
