So How Stiff is the S197 Chassis?
Old 09-18-2010, 06:55 AM
Norm Peterson
Norm Peterson's Avatar
I doubt that the Corvette is as stiff.
Norm
Norm Peterson is offline
Old 09-18-2010, 09:15 PM
Argonaut
Argonaut's Avatar
So I agree that things like the amount of travel, droop of the suspension and even the solid axle are having an effect. But I got to tell you...the difference is dramatic. With literally just a couple pumps of the jack the vette's front and rear wheels are up. It probably takes three times as many pumps or more to get the stang up on two wheels. Maybe the vette is not stiffer as some of you think but I know what I see and it sure looks like it is. But I don't want to argue the point...I'll just accept it as an interesting difference between the two cars, whatever the reason for it.
Argonaut is offline
Old 09-20-2010, 12:21 AM
steelcomp
steelcomp's Avatar
Originally Posted by 908ssp
Sorry Argonaut your description doesn't indicate that the chassis is bending. Wheel travel, sway bar strength and balance point all influence your description.
And uni-body cars are much stiffer than frame cars or space frame cars for the weight. Stiffer and lighter. A formula one car is uni-body. Passenger cars for the street aren't built to be just stiff. They are built to crash well and this requires some flexibility in certain areas so stiffness is not the overriding goal. Old frame cars were much worse. Even truck frames are worse. Jack up a corner of a truck made a few years ago and watch the bed to cab gap close up. A space frame like a NASCAR is stiff but it is built for what it does and there are no doors. I could give a 100 more examples....
X2. The difference is in the suspension, not the chassis.
Also, the '07+ S197s are slightly stiffer/stronger than the '05-'06 because of the GT500 which came out in '07. Ford did some added re-enforcing for the GT500, but incorporated the changes to all '07 models. I know of several who have tested shock tower flex with the '07 and it's almost non existent. I would wager the 07 Mustang's chassis is every bit as "stiff" as the Vette.
steelcomp is offline
mtgldr
02-03-2024 09:00 PM
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
09-17-2015 07:57 PM
Quick Reply: So How Stiff is the S197 Chassis?
