Panhard went caput
Old Sep 23, 2010 | 06:51 PM
NJ3's Avatar
NJ3
I have this same panhard bar without set screws, should I be under my car inspecting it every time I drive it.
Old Sep 23, 2010 | 06:57 PM
Sam Strano's Avatar
Sam Strano
Former Sponsor
No, but if you hear a rattle then you might want to check 'em and snug them up. You could call UMI and see what they have to say, but this is the first time I've seen an actual issue like this.
Old Sep 23, 2010 | 10:06 PM
gmoran1469's Avatar
gmoran1469
Originally Posted by Sam Strano
Hey, what about me? I knew they'd take care of it for you.
Gogo Sam, without mentioning you they might not have hooked me up
Old Sep 29, 2010 | 11:10 AM
gmoran1469's Avatar
gmoran1469
Got the new rod-ends in. Is there a certain type of grease I am supposed to use on these?
Old Sep 29, 2010 | 11:17 AM
Sam Strano's Avatar
Sam Strano
Former Sponsor
Despite there being a zerk, the races are made of delrin--which is self-lubricating. Folks just expect the fitting, so they put it on. Grease will actually attract dirt. If you use some, use very little and a synthetic would be best (water won't break it down).
Old Sep 29, 2010 | 12:15 PM
gmoran1469's Avatar
gmoran1469
Was just making sure, the piece of paper that came with them stated "They are not pre-greased and will require a few pumps of grease before being used".
Old Sep 29, 2010 | 03:59 PM
marcuskeeler's Avatar
marcuskeeler
Originally Posted by gmoran1469
Popped the stock one in.... To my surprise I can barely feel the difference. Don't get me wrong, I CAN tell the difference, it's just that it seems to not make that much of a difference in handling. If anything, the rear end seems stiffer and more planted. What do you guys think? Did you notice a large chance in handling when installing an adjustable panhard with roto-joints?
Firmer bushings or hyme joints will make the rear end more precise but it won't actually change the way the rear end behaves.
Adjustable length PB's are good for correcting rear end offset but that's the end of it.
Old Sep 30, 2010 | 07:33 AM
Norm Peterson's Avatar
Norm Peterson
It doesn't change the geometrically determined part of handling behavior, but the differences in compliance lead to a couple of indirect rear axle steer effects that you can feel, and which will affect response and controllability up toward to the limits of tire lateral grip.
You'd have to be driving pretty hard for these effects to make enough difference to measure in and of themselves, although improved driver confidence (which can't be measured) usually leads to better and more consistent performance.
Norm
Gene K
Oct 21, 2015 11:37 PM
flash_xx
Oct 16, 2015 07:23 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
RWHEELS
Sep 5, 2015 03:42 PM
