Front Lowering Spring Install WITHOUT Compressor?
Old Jan 18, 2011 | 11:38 AM
iceguyb14's Avatar
iceguyb14
Default Front Lowering Spring Install WITHOUT Compressor!
EDIT: Well since its been 119 views and no help, figured I'd post a video I found. This shows how to do it.
http://www.v8tvshow.com/forum/index.....msg194#msg194
I know a lot of people have installed front lowering springs on our cars without a compressor, but I can't seem to find a write-up without using a coil spring compressor. I know theres a trick but cant remember it. Anyway a write-up would be great!!! Thanks
And I already installed the steeda sport rear springs which is why I only need the front install write-up... I just ordered the front springs and would love to install them this weekend.
Old Jan 18, 2011 | 11:37 PM
Avalanch3's Avatar
Avalanch3
Just rent a spring compressor from Autozone or something. All you do is clamp the spring on opposite sides from each other, and slowly go from there.
Old Jan 19, 2011 | 12:19 AM
2005WBvert's Avatar
2005WBvert
My father and I tried it without a spring compressor in my 2003 mach 1 with great success.
But we were met with failure with my 05 GT. We left the top 4 bolts on above the strut and tried lowering the a arm all the way down with hopes the spring would un-compress completely, but weren't even close. Plus there were other parts of the suspension starting to move in ways they weren't supposed to.
Like posted above, $50 at autozone for spring compressor. You get your money back when you return them
Old Jan 19, 2011 | 03:18 PM
azrampage's Avatar
azrampage
Years ago I just bought a good quality spring compressor (they can also be rented) and have ended up using it on quite a few cars over time. One is not that expensive considering everything that could go wrong trying half-a** methods. As stated elsewhere, things don't always release as intended, and the consequences can be severe both physically as well as mechanically.
The good news is that most replacement "lowering springs" will go back on without the need for any compressor, as they are usually significantly shorter than the originals.
My two cents.
Old Jan 20, 2011 | 01:11 AM
CommanderCOOL's Avatar
CommanderCOOL
The process they used in the video looked sketchy. I was able to install my Steeda springs by myself with spring compressors that I bought from harbor freight for $14.99. They were surprisingly good quality and worked perfectly. I was expecting a one time use out of them but they can definitely last.
Another way to perform a spring transfer is to totally unbolt your strut assemblies from the car. have a friend take you to a tire shop or suspension shop where they have a strut assembly compressor machine(call to make sure beforehand) and have them swap out the springs for you(for a price maybe).
Old Jan 20, 2011 | 01:27 AM
Kona6Stang10's Avatar
Kona6Stang10
It's easy.....just use an impact on the top nut. nothing will fly up and hit you unless you're a 65lb child with no upper body strength lol
Old Jan 20, 2011 | 02:59 PM
iceguyb14's Avatar
iceguyb14
Installed the springs in am hour and a half with a friend with no spring compressor. Very easy
Old Jan 21, 2011 | 07:53 PM
allinon72's Avatar
allinon72
Buy or rent yourself a good quality spring compressor. I used one from Harbor Freight and one of the bolts SNAPPED on me, causing me to chuck the spring into the yard in fear that it was going to let loose.
Old Jan 21, 2011 | 08:49 PM
kzonts's Avatar
kzonts
I guess my question would be - "Why would you not use a spring compressor?" They are FREE from your local auto parts store.
Old Jan 22, 2011 | 05:22 AM
iceguyb14's Avatar
iceguyb14
It's easier and faster not using one, and safe if you do it right. And you don't have to make 2 trips to the store... Those reasons seem good to me lol
