Speedometer / Oddometer issues
Old Apr 1, 2013 | 10:46 PM
07V6's Avatar
07V6
Default Speedometer / Oddometer issues
Hi all. New member here thanx to the 2007 Mustang I recently purchased. I took it to work the last month and noticed that the odometer registered the trip as 1.6 Kilometers (yes...I'm in Canada) more than my other cars. I checked the speedo using my GPS and discovered it was out by quite a bit. At 60 KPH (about 38 mph) my GPS shows I was only doing 50 (31 MPH) , and at 120 (75 MPH) GPS said I was only doing 100 (62 MPH). I had it checked by an independent shop and the tire size (P235 55 Zr17) was programmed correctly with a 311 rear end. I took it to Ford (twice) and they played with for an afternoon while it was connected and I went along for the ride. Long story short, they couldn't fix it. The Ford program only allowed 4 different options for tire size and two for rear end differential and none of them seemed to make a difference. I checked the forum and it has been addressed before but nothing offered seems to apply. I think 13 MPH out at hiway speeds is a little bit too excessive and Ford has no idea how to fix it. I bought it used with VERY low mileage, and if this has been going on since new, I figure it has about 1200 miles more on the odometer than it has actually driven. Other than that, I am enjoying the car and it is just plain fun to drive. Any help or suggestions would be appreciated. THANX!!
Old Apr 2, 2013 | 12:26 AM
modman42's Avatar
modman42
The factory gears should be 3.31 not 3.11. That may be your issue. I would verify the gear ratio before going any further.
Old Apr 2, 2013 | 07:24 AM
07V6's Avatar
07V6
Sorry...I meant 331. Was going from memory. The tire size and diff were set to default setings.
Old Apr 2, 2013 | 06:27 PM
modman42's Avatar
modman42
Sorry I can't be more help I have not had this issue. By the way welcome to the forum!
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
