Tire help
Old Apr 23, 2013 | 02:32 PM
jdphillips73's Avatar
jdphillips73
Default Tire help
Sorry if this has been answered before, I spent the past hour using search... no luck
I have 17x 8 wheels on my 07 mustang.. It has the original pzero 235/55/17 tires. I know that changing tire sizes throws off the speedo (my tuner allows me to input tire sizes)
Heres my question:
How wide can I put on the back of my car without rubbing, or being to wide for my rim.
These are the exact wheels that I have on my car. http://www.newtakeoff.com/chrome_mus...t_of_four.aspx
Old Apr 25, 2013 | 02:26 PM
UrS4's Avatar
UrS4
255/50/17 won't throw off the speedo or rub
Old Apr 25, 2013 | 02:36 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Any tire that maintaine the same or close to overall height of the tire won't affect the speedo. DO NOT assume that a tire that has the same aspect ratio will mean it's the same height. You can have a skinny tire with the same aspect ratio that will end up shorter that your stock tire or a fat tire with the same ratio that will end up taller.
As for rubbing and such, I belive 295 is as fat as you can go no the rear, 275 on the front.
Old Apr 25, 2013 | 07:14 PM
jdphillips73
Thanks, I went ahead and pulled the trigger on a set of 255/50/17 nitto 555's with a 1" spacer on the back... i'll let you know how it turns out when they come in...
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
