Shock mount question
Old May 23, 2013 | 06:31 PM
CAR-15's Avatar
CAR-15
Default Shock mount question
I bought a set of slightly used FRPP Shocks and Struts. I need to finds the parts pictured below.
I am not sure if I can use the ones that are on my car now. The are OEM.
Old May 23, 2013 | 06:56 PM
mayo's Avatar
mayo
You should be able to use the original rubber mounts with the new shocks. I would give them a try before I set out on a mission to find new ones.
Old May 23, 2013 | 06:58 PM
CAR-15's Avatar
CAR-15
Lol, I hear ya. I am just trying to make sure when I go to do this I have everything. A friend that owns a shop lets me use his lift on a Sunday if I need it so just want to get my ducks in a row so it is a one time installation.
Old May 24, 2013 | 05:52 AM
Scott2's Avatar
Scott2
+ one. You should be able to use the parts from your car. Should be a plate and bushing on the bottom and a plate and bushing with a nut in the trunk (for each side). Make sure you have a method of holding the shock shaft top before you start as you need to hold the shaft so you can break the nut free otherwise the shaft may just spin.
Tivo304
Aug 28, 2023 12:19 PM
67STANGX2
Sep 24, 2015 12:29 PM
04stangman
Sep 17, 2015 01:45 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
