Stock shelby ?
RE: Stock shelby ?
Here's some info I found...
Type
V-8
Manufacturing location
Romeo, Michigan
Configuration
Iron Block and Aluminum Heads
Intake manifold
Cast-aluminum with Roots-type supercharger and air-to-water intercooler
Exhaust manifold
Cast iron
Crankshaft
Forged steel
Throttle Body
Dual 60 mm, electronic
Valvetrain
DOHC, 4 valves per cylinder
Valve diameter
Intake: 37.0 mm; Exhaust: 32.0 mm
Pistons
Forged aluminum
Connecting Rods
Cracked forged steel I-beams
Ignition
Coil-on-plug
Bore x stroke
3.552 x 4.165 in. / 90.22 x 105.8 mm
Displacement
330 cu. in. / 5,409 cc
Horsepower
500 hp @ 6,000 rpm
Torque
480 lb.-ft. @ 4,500 rpm
Compression ratio
8.4:1
Redline
6,250 rpm
Idle Speed in Neutral
750 rpm
Engine control system
Spanish oak PCM
Recommended fuel
Premium only
Fuel capacity
16.0 gallons
Fuel Injection
Electronic returnless sequential
Oil capacity
6.5 quarts 5W-50 Full Synthetic
Coolant capacity
21 quarts
Type
V-8
Romeo, Michigan
Configuration
Intake manifold
Exhaust manifold
Cast iron
Crankshaft
Forged steel
Throttle Body
Valvetrain
Valve diameter
Pistons
Forged aluminum
Connecting Rods
Ignition
Coil-on-plug
Bore x stroke
Displacement
Horsepower
500 hp @ 6,000 rpm
Torque
Compression ratio
8.4:1
Redline
6,250 rpm
750 rpm
Spanish oak PCM
Recommended fuel
Premium only
Fuel capacity
16.0 gallons
Fuel Injection
Oil capacity
Coolant capacity
21 quarts
RE: Stock shelby ?
Just wondering if the GT500's have forged internals stock? and if so or not, what's the most amount of hp u can run on them safely w/the stock set-up?
All signs point to 650rwhp being the "safe" limit of power, somewhat similar to the Terminators.
Obviously there will be people out there pushing the envelop with varying degrees of success.
Here is a quote from John Lund after talking to the Mahle engineer that designed the rod/piston combo for the GT500:
"After a recent visit to Roush and SVT in Dearborn with the EVO machine we were able to gather alot of excellent test and research data on the GT 500. We also meet up with the Maule engineers and actually had a great conversation with the guy that designed the Rod and Piston Combo. The Piston is a stout unit although it is near the same desing as the Ford GT it isn't the exact same piston. Some slight design differances in the Ring land for oil control and some very slight weight differances but in and of itself a very stout design and much stronger than the 03/04 Cobra piece.
The Rods are indeed a craked forged I-beam design. The engineer indicated a 650-675 crank HP range was nearing the limit but more important was the RPM limit. They could handle quite a bit of load as long as the Revs were kept in tact. He indicated the more power being made the lower the rpm. Stock Rev is 6250 for that reason so I'd once these KB units start making it to streets I think we will see more internal rod damage and some blown motors just due to purely exceeding the Rods design capability."
movielover40
09-10-2015 03:34 PM
Other Professional Racing
09-10-2015 11:41 AM
