S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
5w 50 oil
Old 02-06-2010, 10:16 AM
JOHNNY
JOHNNY's Avatar
Default 5w 50 oil
Did the first oil change on the 2010 gt500 it takes 5w50, only syn. I could find was castol, what everone using. Advance had a Mobil one special 5 qt of mobil one and a mobil one filter for 27.00 but only had 5w30 and 5 w20.
JOHNNY is offline
Old 02-06-2010, 10:50 AM
Nuke
Nuke's Avatar
Any name brand oil of the proper weight is fine. Just be sure you change it at a frequency that is appropriate for your driving style.
Nuke is offline
Old 02-06-2010, 12:10 PM
6-Speed
6-Speed's Avatar
Castrol Syntec 5W50 is fine for the GT500; it meets/exceeds the Ford WSS-M2C931-B spec recommended for it. I have been using the Motorcraft 5W50.
http://www.castrol.com/liveassets/bp...syntec_usa.pdf
6-Speed is offline
Old 02-06-2010, 11:14 PM
moburto07GT
moburto07GT's Avatar
I have been using the Castrol 5w-50 in mine without any problems. Its about $7 a quart where as the Ford dealerships in my area wanted a little over $10 a quart for the Motorcraft 5w-50. And as far as using the Mobil 5w-50 i believe you may have to special order it.
moburto07GT is offline
Old 02-08-2010, 07:38 AM
yc420
yc420's Avatar
I use the Motorcraft 5w-50 motor oil. I pay $7.19 a quart for it. I order it online from: http://k-mansparts.com/items/mustang...qgt-detail.htm
yc420 is offline
Old 02-09-2010, 09:22 PM
whitegt500
whitegt500's Avatar
yea same here, use the castrol 5w-50, cost around $50 for a oil change with the filter, dont think any drive thru oil places carry that oil
whitegt500 is offline
Old 02-10-2010, 06:47 AM
05 Mustang
05 Mustang's Avatar
I use Castrol 5w-50
05 Mustang is offline
Old 02-10-2010, 08:07 PM
oldlugs
oldlugs's Avatar
Originally Posted by JOHNNY
Did the first oil change on the 2010 gt500 it takes 5w50, only syn. I could find was castol, what everone using....
I recommend that you use nothing but the MotorCraft 5w-50 for now. I think the only other oil that met the correct Ford spec. was sold by Roush, but it's no cheaper. Plenty of folks use the Castrol, and some the Mobil 1 5w-50 (European, I think), but I believe those don't meet the Ford specification for the GT-500. They probably work just as well (or better), but may shorten the exhaust catalyst's life. However, if warranty is any concern, stick with the MotorCraft. If any engine oil related issues come up, you can be certain Ford will have your oil lab tested.
oldlugs is offline
wraith777
09-28-2015 10:49 AM
Shadow7874
09-24-2015 09:06 PM
belam
Oil and Oil Related Topics
09-23-2015 11:29 PM
Demodulates
09-18-2015 11:14 AM
kevsgt
09-09-2015 06:20 AM
Quick Reply: 5w 50 oil
