S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
(-) door trigger wire functionality?
Old Apr 27, 2010 | 11:31 PM
cabala's Avatar
cabala
Default (-) door trigger wire functionality?
Hi all,
Can someone help me understand the electrical function of the negative door trigger wire in reference to the map light circuits in the overhead console?
I have the wiring diagram but it doesnt seem to show the full functionality. I would post the schematic but can't. The schematic describes it as the "dome lamp return" that enters the "smart junction box" from the overhead console, but what does it return to? Chassis ground? Is it floating?
Is the relay (switch) depicted in the overhead console box, the two manual buttons in the car that when depressed turn the map lights on no matter what? That seems to make sense. IF that is the case, there must be some switch downstream (or in the SJB) that connects the light green/yellow negative door trigger wire to chassis ground when either door is open right?
Thanks for the help and hopefully this makes sense without the wiring diagram.
Shawn
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
breaking
Oct 2, 2015 01:27 PM
Sep 25, 2015 06:58 PM
