S197 Shelby Section This section is for technical discussions pertaining specifically to the latest installment of the Shelby Mustangs; the Shelby GT, the CS6, and the awesome GT500.
gt500 brembos onto regular Gt
Old Sep 3, 2011 | 02:00 PM
sjuliani's Avatar
sjuliani
Default gt500 brembos onto regular Gt
I have a 08 mustang Gt and was thinking about swapping over the front brake set from a 09 Gt500. From what i read the brake booster and master cylinder are the same but i would need to change the front spindles, calipers and rotors, is this all i need?
Old Sep 4, 2011 | 05:54 AM
jpplaw's Avatar
jpplaw
All you need is caliper and rotors. There is no need to change spindles
Old Sep 4, 2011 | 10:41 AM
scottybaccus's Avatar
scottybaccus
Every GT500 started life as a GT. Allthe parts are a direct fit.
Old Sep 4, 2011 | 10:46 AM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Gt500s aren't modified GTs
they're assembled seperately at the Ford plant, though perhaps on the same lines, not sure about that.
Old Sep 4, 2011 | 12:05 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
They are all made on same frame and underpinnings. They will attach with no problems.
Old Sep 4, 2011 | 09:10 PM
scottybaccus
I believe the word would be "optioned" GT. They are a Mustang GT.
Old Sep 5, 2011 | 09:12 AM
jpplaw's Avatar
jpplaw
Don't forget the GT500 wheels. Regular GT wheels will no longer fit once you put the Brembo's on.
Old Sep 7, 2011 | 02:18 AM
Orion_240's Avatar
Orion_240
I take it you will not be using the base GT 17" or 18" wheels with the bigger brakes?
Old Sep 9, 2011 | 04:58 AM
jpplaw's Avatar
jpplaw
Base 17" and 18" GT wheels will not fit over the GT500 Brembo calipers. You must use
GT500 wheels.
Bokeo
Oct 10, 2015 08:28 PM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
GLOCKer
Sep 28, 2015 07:36 AM
