Extreme clutch?
RE: Extreme clutch?
ORIGINAL: Jazzer The Cat
Be a little careful with the Centerforce as the weights that are in play can come off and give some serious balance issues inside the pressure plate.
Jazzer
ORIGINAL: Saleen05797
I just ordered a Fidanza aluminum flywheel to pair up with my centerforce clutch. Hopefully they like each other well enough [8D]
Jazzer
RE: Extreme clutch?
What do you mean by be careful?
Jazzer
Jazzer
I recommend the Mcleod Mickey is running if you are going high HP. I am running a stock 11" as the dealer made a mistake as I wanted the King Cobra 10.5" clutch. By the time I figured it out, it was a Sunday and car was all apart. No matter, really, as I am running stock HP and the clutch is completely effortless to use.
You can help your RPM acceleration by going with a 10.5" or 10" clutch (the smaller will "spin-up" faster). It will help RPM's climb a little faster whengiving grandmarunning a full-race'73 Pinto wagon a taste of "what for"asshepipes you at that stop light!
The Jaz
RE: Extreme clutch?
I am kinda surprized that Saleen uses an 11" clutch on the "E" cars. I would think they would go with 10.5" or maybe even a 10".
RE: Extreme clutch?
ORIGINAL: sowaxeman
I'm hoping that was sarcasm [&:] Ford hasn't used a 10" clutch since 1985.....I know, because I just installed a new OEM clutch kit on my '85 GT vert a few weeks ago. Its been 10.5" since 1986 and now apparently up to 11".....why go backwards, especially on a horsepower beast liken an E?!
Jazzer
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
09-16-2015 07:53 PM
