Rattling noise under the engine. Bad motor mount?
Old Feb 22, 2018 | 08:58 PM
DenissK's Avatar
DenissK
Default Rattling noise under the engine. Bad motor mount?
98 GT.
Recently I started hearing a rattling noise under the engine when at idle. When I open up the hood, I can't hear it. I can only hear it if I only look under the car. Sometimes there is no noise, sometimes it is not as loud.
I know for sure that I have one or several motor mounts going bad as I hear a clunking noise sometimes when I shift gears. I am just wondering if bad motor mounts can cause rattling?
The engine does not vibrate or move from one place to another when accelerating. I can't hear the noise when driving in the car.
Finally, could bad motor mounts cause subtle misfire like surges when driving in certain gears/ RPM ranges?
Old Feb 22, 2018 | 11:41 PM
Check all the heat shields first, they are usually the culprit for
rattles under the car.
Motor mounts will not cause misfires.
You do not have several motor mounts, two, and one trans mount. The motor
will twist if one of the motor mounts are bad.
Clunking could be the differential, universal joints, or transmission.
I had a rattle on another car, and it was the heat shield; broke at the bolt and
was making the noise at the break, the motor was vibrating on it.
Old Feb 23, 2018 | 11:18 AM
DenissK's Avatar
DenissK
Old Feb 23, 2018 | 11:20 AM
DenissK's Avatar
DenissK
I went under the car and the pice pictured above was loose. I know it is bad a pic but I did not have much clearance to take a better pic. It is mounted on the side of the transmission across from the 02 sensor on the driver side. I touched it and it was wiggling a bit. I don't know what it is so I did not try to remove it. No bolts are holding it.
What is it?
Old Feb 23, 2018 | 01:22 PM
Urambo Tauro's Avatar
Urambo Tauro
Hard to get a sense of where you were pointing the camera there, but the first thing that comes to mind is maybe this is a close-up of the clutch fork cover?
Old Feb 23, 2018 | 01:46 PM
DenissK's Avatar
DenissK
Yeah, I looked up how that cover looks like and yeah, that is the one. Can it cause the rattling?
Old Feb 25, 2018 | 10:49 PM
Urambo Tauro
If it's loose, yeah. Did you check the heat shields?
Old Mar 20, 2018 | 07:26 PM
DenissK's Avatar
DenissK
I could not find any. I googled them and I could not find anything that looks like a heat shield in that area.
SANANTONIO06GT
Jun 3, 2009 07:53 AM
tx65coupe
Apr 6, 2009 07:34 PM
kcmarti
Aug 13, 2008 05:24 AM
notstock02gt
Jul 28, 2005 05:30 AM
JJ94GT
Mar 15, 2004 12:18 AM
