Just some tips for 3.8 owners
I recently replaced my 2001 mustang v6 engine with one from a 1996 mustang 3.8, and everything works perfectly. Just as long as u use the harness for the engine you use because 1994-1998 have different harnesses as 1999-2004. And the only problem you will have is that the cluster will have to be modified for a older engine because in mine my temp and oil gauge won't work so I installed aftermarket gauges. Just don't let people tell you that engines won't fit your car all you gotta do is modify it to work.
1996 mustang 3.8 engine in a 2001 mustang
