5.4 3v tuning?
Old Jun 7, 2021 | 07:52 PM
04_lariat_ben's Avatar
04_lariat_ben
Default 5.4 3v tuning?
Ive posted here a while back, i have a 2004 F-150 5.4 3v 4x4(i know its not a 4.6 mustang) but with similar design i thing you mustang guys can help me. I have done a FRPP "hot rod" cam swap a while back and have been driving around with it for almost a year now, the engine shakes at idle speed, but cannot find and vacuum leak and the truck has great response and power gain from the swap. I even pull a car trailer loaded down with atvs and it pulls better then stock. I have more upgrades that have gone along with the cams such as CAI, Long tubes, full magnaflow exhaust, 24# FRPP injectors, accel coils and so on. The motor was fully torn down and installed melling hf/hv oil pump, MMR tensioners and guides, FRPP rocker/lifters. And tranny "4r75w-4x4" was upgraded with 2200 stall, stage 1 Raybestos clutches, and "custom" trans-go shift kit. I still have not installed the 4.11 gears yet, but i would like to see if i could get a dyno tune to see if that may fix my idle shake issue, it idles around 680-750rpm with no big surges on 87oct, but runs the same if not better on 89oct. So if anyone has any suggestions on either a fix or a good dyno in Louisville, KY that be great, thanks in advance and sorry for rambling.
Old Jun 9, 2021 | 03:57 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
You changed a major major engine component and didnt tune it for a year while beating around in it ? First thing you should have done was get it tuned
Old Jun 11, 2021 | 07:58 PM
04_lariat_ben
the truck has an email tune from Power Hungry Performance, they have done research on the 5.4 2v and 3v and have been great so far but i want more fine tuned, due to PHP being specialized to Ford diesel performance. Sorry for the late reply
Old Jun 15, 2021 | 11:30 AM
Definitely not a "fix" thing. You need a dyno tune. Can't help you in that department but, just iterating what the ideal solution is.
Old Jun 15, 2021 | 12:12 PM
365Saleen's Avatar
365Saleen
The engine is not going to idle smooth with those cams in it. It is supposed to have a bit of chop or gallop.
04_lariat_ben
Mar 8, 2021 06:06 PM
jdmcbride
Apr 18, 2009 04:18 AM
Not1My1Fault
Nov 9, 2008 11:40 AM
Rubrignitz
Nov 6, 2008 08:18 PM
98blackgtinsc
Jul 16, 2007 11:29 PM
