Primed oil has air
Old 05-02-2024, 11:37 AM
PSPete
PSPete's Avatar
Default Primed oil has air
New stock 302 engine with double roller and "towing Cam". Replacing 347 I ran for three years. It's cam is wearing so I took it out of the car.
Plans are to rebuild the 347 in a couple of years and find an 86 Mustang Hatchback or Convertible for the 347.
Presently.
When I use the drill to run oil pump and hose connected to the oil pressure sending hole it pumps oil as a stream out the hose. But after a while it becomes mixed with air and spits.
I understand air entering the pump and pickup screen. I am running and HV pump and Scott Drake from sump pickup and baffled 6 qt. pan.
This is the same set up I used in the 347. Just use the old and new pump and pick up screen.
My question is can the intake galley plug when leaking or popped out produce air coming out of the hose set up I am using.
Can a problem with the galley plug that far back from the pressure output produce air in the oil steam?
Other comments?
PSPete is offline
Old 05-06-2024, 01:49 PM
PSPete
PSPete's Avatar
Default Fixed
Scott Drake front sump custom (Centered) for 6qt Oil pan. Pickup was not machined flat. I have two other Scott Drake oil pickup
that have machining on the surface that matts up to the oil pump. Bummer.
PSPete is offline
Old 05-06-2024, 03:40 PM
drhoward
Penis Mod Erator
drhoward's Avatar
I wouldn't even have thought to check that, I always just slap them on and go
drhoward is offline
polo708
04-21-2013 06:35 AM
89GTBlake
08-07-2009 07:25 PM
90orangenotch
03-08-2009 07:40 PM
Cisco 5.0
06-25-2008 10:56 PM
88GT40
04-03-2005 12:47 AM
Quick Reply: Primed oil has air
