Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
speed density
Old Feb 13, 2008 | 08:07 AM
  #71
stangbanger87's Avatar
stangbanger87
Default RE: speed density
yes it is , i am getting a bone yard 351w here in the next few weeks (my dads buddy has a boneyard )to start a 427 stroker he also has a 4banger notch i have been trying to talk him out of to put this striker in .i was going to pick these up and stickem in my moms garage as she only uses the one side until i can get the parts and time to get to it , this one will take a long while , i might have it ready by the time i decide to retire . but far as it goes NO they are never fast enough
Old Feb 13, 2008 | 04:08 PM
  #72
dimebag's Avatar
dimebag
nope never gets fast enough... i havent even put my rear in yet lol...
idk i gotta do something, leaning towards a centri
Old Feb 13, 2008 | 06:18 PM
  #73
stangbanger87
i know if they are done you have either sold it or you're dead is how i look at it .
Old Feb 13, 2008 | 09:27 PM
  #74
pimpinstang1's Avatar
pimpinstang1
ok im done im sticking with SD :
Old Feb 14, 2008 | 02:20 PM
  #75
stangbanger87
sd is good but eventually you will have to lose the stock ecu. you can max the stock config so far and that is it . the stroker i am planning on building is going carb!
Old Feb 14, 2008 | 06:14 PM
  #76
crdsaleen's Avatar
crdsaleen
Tech question:After I rebuilt the engine it has been running real rich and fowling plugs.Its speed density,Crane compucam,New fuelrails with regulator,19or 24 lb injectors I forget from Explorer302,70mm throttle bodyand spacer,cartech breadbox intake,MSD coil and MSD box.Can anybody give me some advice to tune this car.
Old Feb 14, 2008 | 06:35 PM
  #77
stangbanger87
well the bread box intake is a part of it ,if you have 24#injectors that is a big part of it as stock sd is only compatable with 19# and no bigger .are you useing stock sd or a stand alone efi.
Old Feb 22, 2008 | 12:54 AM
  #78
enoughsaid's Avatar
I have a question. I have never dealt with SD and i just got an 87 5.0 notch 5 speed with SD. I was considering switching to MAF. If I am looking to run around 350 hp what should I do? I will be changing heads and upper/lower intake along with a basic rebuild(pistons, rings, gaskets, etc.) How hard is it going to be with an SD setup? Any help is appreciated.
Old Feb 22, 2008 | 02:40 PM
  #79
stangbanger87
themost important things to remember with sd is the cam lobe seperation must maintain 114 degrees seperate and 19# injectors is the biggest you can run with stock sd .and that nos is our friend with sd
Old Feb 22, 2008 | 04:56 PM
  #80
enoughsaid's Avatar
I have never messed with NOS. What would be an appropriate shot? Can I get around 350 hp without nos with the stock SD? If so what mods should I start with? I was planning on gt40 heads, explorer upper and lower. I would like to go with a cam too. Also what cam can I run? Sorry about all the questions. I have a lot of experience with diesel and chassis but not aftermarket.
