Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
GT-40 components w/ SD
Old Mar 27, 2008 | 05:54 PM
camaroeater's Avatar
camaroeater
Default RE: GT-40 components w/ SD
ORIGINAL: stangbanger87
that is with a cam and i would go with the 58cc to keep it close to the 9.1 compression , might peak the hp a little more seeing how the set up i have droped mine to like 8.8:1. i see you run your timeing maxed , do you have any trouble with it wanting to drag once the car is up to normal operateing temp?
I was gonna say thats a good HP increase w/o upgrading the cam. I thinking of the crower 15111, only heard good about it everywhere. I was thinking of doing crane 1.7 roller rockers on either GT40/ps or the GT40x's.As for the timing, by drag do you mean the rpm's flucuate, b/c when warmed up at idle it might drop like 50 rpms or so.
Old Mar 27, 2008 | 06:19 PM
stangbanger87's Avatar
stangbanger87
i just ment far as starting does it want to crank slow when it is up to temp , i ran mine at 14 and it wanted to drag abit once it got up to opperateing temp.
with the 1.7's and that cam you should br good to go .
Old Mar 27, 2008 | 06:38 PM
camaroeater
No, mine cranks over fine. The cam table doens't show spec w/ 1.7rr's. Am I supposed to use 1.66rr's?
Old Mar 28, 2008 | 06:36 PM
stangbanger87
it does with the cams that you can run 1.7's with , the others can not have bigger than 1.6
Old Mar 28, 2008 | 11:37 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
dimebags car....
gt40 heads
gt40 intake
comp cam, 218/224 at 50, .512/.512 114lsa
car runs great, daily driven, or was untill i got my 02. it idled fine, but i did somethings to make that happen. others have had problems w. that cam
btw its dimebag posting
Old Mar 29, 2008 | 03:16 PM
stangbanger87
good to see you still help out here on the sd section there dime i figured you would be all new edge by now lol
6bangr
Feb 15, 2016 07:40 AM
Gene K
Oct 21, 2015 11:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
