Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
GT-40 components w/ SD
Old Mar 25, 2008 | 09:52 AM
camaroeater's Avatar
camaroeater
Default GT-40 components w/ SD
I plan on getting a Cobra intake, FRPP headers, and some used GT-40P heads. How well would this setup work with SD cause I don't want to do a Mass Air conversion.Is anyone running a similar setup w/o problems?
Old Mar 25, 2008 | 12:53 PM
stangbanger87's Avatar
stangbanger87
Default RE: GT-40 components w/ SD
i am running the 40p top end on mine the frpp headers might have some issues mounting to the head and giveing plug clearence ,far as useing the cobra intake idk you would have to ask nitrousd85 about that he is runnin the 40 head and cobra intake.
i would think you would have no trouble with that set up .
Old Mar 25, 2008 | 01:27 PM
camaroeater
I meant to say the FRPP P-headers....I thought GT40 upper/lowrintake would be compatible with GT40p heads and vice versa. So I thought a cobra upper/lowr intake could run w/ GT40/P heads.
Old Mar 25, 2008 | 02:32 PM
87 T TOP GT302's Avatar
87 T TOP GT302
I've got an 87 gt withprofessional products intake with 65 mm t/body 93 cobra heads w/1.7 rr and mac 1.5 equal length shorties. It idles great and is still speed density.
Old Mar 25, 2008 | 06:14 PM
stangbanger87
yeah camaro eater it should work fine seeing how as the flow numbers on the intakes are pretty close .you shouldn't have any issues with it
Old Mar 25, 2008 | 06:34 PM
camaroeater
Cool...thank alot. Sometimes I lean towards doing the MAF conversion, I'v decided I want to take SD to the limits w/o having problems.
Old Mar 26, 2008 | 09:29 PM
stangbanger87
now the best hp you will see with stock sd is like 280 at the rear tires but if you use like a 100 shot spray it should get you in the 300+ range .now if you want more hp you will have to look towards megasquirt or xfi to stay sd or go maf or go carb.
Old Mar 27, 2008 | 12:03 PM
camaroeater
ORIGINAL: stangbanger87
Could I make this power with or w/o a cam? Also, as for new GT40x heads, do I want the 58cc or 62cc. Thanx stangbanger87
Old Mar 27, 2008 | 05:34 PM
stangbanger87
that is with a cam and i would go with the 58cc to keep it close to the 9.1 compression , might peak the hp a little more seeing how the set up i have droped mine to like 8.8:1. i see you run your timeing maxed , do you have any trouble with it wanting to drag once the car is up to normal operateing temp?
Old Mar 27, 2008 | 05:36 PM
stangbanger87
here is a list of cams that work with sd . the green ones are the onse that work with ni modifactions to the map andthe orange need some tweaking to work well with the sd
