Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Help with carb idle problem!!!!!!
Old Apr 6, 2008 | 09:04 AM
cjcobra99's Avatar
cjcobra99
Default Help with carb idle problem!!!!!!
I bought a 1984 mustang gt hatchback. The guy I bought it from converted it from TBFI to Carb. I got the car to run now, but I have to have the idle set up to about 2,000 RPM in order for it to not die when I put it in drive. In drive the car idle's at 900 to 1000rpm. What would cause the motor to die out when I put it in drive???? Could this be a bad ignition module? The car has new plugs, wires and new MSD ignition coil. From day one I had a timing issue which I fixed last night. He didn't have the car at TDC when he installed the distributor...he was in a hurry. I have that issue fixed, but the timing my need to be dialed in with a light still...could that be the problem? I don't feel like it's timing because now when I drive the car it pops like it has a miss in it. Someone let me know something????
Old Apr 6, 2008 | 09:51 AM
Gary H's Avatar
Gary H
Default RE: Help with carb idle problem!!!!!!
Sounds like a vacum leak somewhere. What intake and carb?
Old Apr 6, 2008 | 10:25 AM
cjcobra99's Avatar
cjcobra99
Holley 670 street avenger and edlebrock intake
Old Apr 6, 2008 | 10:45 PM
67mustang302's Avatar
67mustang302
Definately check for vacuum leaks. Also, have you set the idle mixture?
Old May 4, 2008 | 09:39 PM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Remove the vac advance line and leave it plugged to see how it runs. I can't use any part throttle with mine so I just left it unhooked.
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
