Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
how well will it run ?
Old Aug 22, 2008 | 02:04 AM
lsxoo7's Avatar
lsxoo7
Default how well will it run ?
i got a few things in the mail ...
ecam
long tubes 70mm tb and rpm2 intake manifold ..
4.10 gears
electric fan
cold air
255lph pump
and 100-150 shot of nitrous ..
its a sd 88 coupe ..
im eventually going to conver to maf when i do sum serious upgrades but how well will it run as is ? a buddy of mine said to not even try it would run like crapo but im not sure if hes right .. any input ?
Old Aug 22, 2008 | 02:18 AM
jtmustang's Avatar
jtmustang
hey there ,
and yes your buddys right well atleast with the cam as the speed density cars do not like cams,injectors or anything like that .
the intake ,headers, and such will be fine , but do your self a favor first swap over to maf and then swap the cam out and such.
Old Aug 22, 2008 | 08:06 PM
mustangjon's Avatar
mustangjon
the tb is prolly a bit big for whats done, but should be workable, still could cause some sd issues some have had issues going over 65mm and others have not.. but the cam is going to be issue as stated
Old Aug 24, 2008 | 02:14 AM
enoughsaid's Avatar
enoughsaid
The tb will be fine I run a 70mm bbk and have never had a problem. SD cars are fine with cams as long as you stay within the perimeters. That e cam though will be a problem as stated by jtmustang. Everything else should be fine until you switch to maf. I would wait to run the nitrous. You will probably run the nitrous different when you switch to maf anyway. It will save you time and money.
Old Aug 26, 2008 | 12:31 PM
Night Terror's Avatar
Night Terror
should run strong, at WOT your pulling 0lbs of vac any way so its not like the SD computer will be like "wtf mate"
Old Aug 26, 2008 | 12:42 PM
lsxoo7's Avatar
lsxoo7
thats what i was also thinking .. im more interested in wot racing not putting around town .. i might just do everything .. if it dosent run too well ill just get the maf conversion done sooner . anyone else think it will run good at wot ??
Old Aug 27, 2008 | 01:35 AM
jtmustang's Avatar
jtmustang
^^^did u get the intake...??
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
