Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
Carburator help
Old Jan 9, 2012 | 11:54 AM
ColamanGT's Avatar
ColamanGT
Default Carburator help
600CFM Edelbrock #1406 on an '87 5.0.
When i get on the pedal, seems like there could be alot more power pushing out.
Running 6.5 fuel psi.
Where to start troubleshooting?
Old Jan 9, 2012 | 11:11 PM
mattdel's Avatar
mattdel
Make sure the secondaries are functioning, check float levels, accelerator pump..
Basically anything in the carb could cause this.
Old Jan 11, 2012 | 10:34 PM
tinman's Avatar
tinman
Check for vacumn leaks..........
Old Jan 14, 2012 | 09:14 PM
SmallblockPower's Avatar
SmallblockPower
600 CFM carb is a bit big for it. Unless you have a good cam in it. You may have a carb too large. Or a vacuum leak as was stated by Tinman. If you have a nasty cam in it try going a larger size or ask your local Speed Shop for more info.
Fox85
Aug 8, 2005 06:44 PM
blowninjected
Apr 11, 2005 09:42 AM
blowninjected
Apr 9, 2005 01:59 PM
MADE2GO PONY
Mar 8, 2005 07:33 PM
TheGmKiller331
Feb 23, 2004 10:00 PM
