StangSuspension.com Your source for late model Ford Mustang suspension parts and performance!
Coil Spring Compressors????
Old Mar 27, 2006 | 01:25 PM
BBKBadBoy's Avatar
BBKBadBoy
Default Coil Spring Compressors????
I was wondering about this item i saw for sale at my job, it is called coil spring compressors, it says you can bolt these down onto your coil spring and it will compress the coil springs to give you a lower 1 1/2 to 2in. drop, have you heard anything about this??,
here is a pic of what im talking about http://www.carparts.com/wcsstore/car...e/10012762.gif
Old Mar 28, 2006 | 01:05 AM
STANGSUSPENSION's Avatar
STANGSUSPENSION
Former Sponsor
Default RE: Coil Spring Compressors????
Well yes that is a coilspring compressor, but I dont believe its designed for permanent installation.
Those are usually designed to compress the spring down for installation/removal of the spring, not for dropping the car...
This I KNOW would be dangerous...
Old Mar 28, 2006 | 12:03 PM
BBKBadBoy's Avatar
BBKBadBoy
Yea i know they have a Spring Compressor which is used for Installation and Removal but this is particular product is a small Spring Compressor which locks two coil springs down, and is designed to keep to springs compressed down at all times, which i thought also could be dangerous like you said, i think they are used mainly on trucks though
Old Mar 28, 2006 | 07:19 PM
STANGSUSPENSION
Former Sponsor
Yeah I would stay away from that. At the most, I'd remove a spring isolator, or go with lower springs...
Sincerely,
Old Mar 28, 2006 | 10:02 PM
weasel1088's Avatar
weasel1088
Those things are dangerous as hell. careful if you use them, and yes its just for install and removal.
Old Mar 30, 2006 | 10:34 AM
MustangChris04's Avatar
MustangChris04
is it bad to remove the rubber on the top and bottem of the spring?
If i am install steeda lowering sport springs would I need a compressor?
firehorse02
Nov 16, 2015 11:28 AM
fastbackford351
Oct 1, 2015 12:24 PM
mungodrums
Sep 28, 2015 10:54 PM
Sixer4Life
Sep 28, 2015 07:05 AM
