LOWERING SPRINGS ON THE VERT
Well the Ford B & C springs are one of the only spring sets with a great reputation, under $200...
You can try these http://www.stangsuspension.com/store...?idproduct=834 the Ford G springs which are specifically made for a convertible... but CC Plates will probably be needed...
You have to find your budget first, and try to find the parts which fit into that budget...
I think I can livw with the C or B set, assuming the fact that my rear end will not be closer to the tires than the front fenders will. I would like it to be equil, or even a little lower in the front. Which one of these will give me the desired look. Also, you dealing with these as much as you do, have you ever seen a 94-98 vert with the c springs, and did it lower it, and did it look decent? I think I'll go with the c's because of the handeling aspects. Thanks for you help on this...when I buy I know where I'll be going.
The B and C springs are mile drop springs... dont expect a drastic appearance difference... it is very subtle.
Performance is increased although substantially with the C springs, and moderately with the B springs...
Sincerely,
Sincerely,
mungodrums
Sep 28, 2015 10:54 PM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
