StangSuspension.com Your source for late model Ford Mustang suspension parts and performance!
Camber Bolt Question?
Old Jun 15, 2006 | 12:11 AM
06GT4RAD's Avatar
06GT4RAD
Default Camber Bolt Question?
Hey Josh i finally looked at the camber bolts i purchased from you and have noticed that they do not say they are for the Ford cars. So i have a few questions. One is after looking at the bolt kit i notice the washer has an index tab built into it yet no where on the Tokico Struts will it fit. So where exactly do the bolts go top hole or bottom hole and what am I suppose to do with the Washer. See this picture from your site and you will understand. Also the bolts have a torque spec on them based on model number on the box which is 81260 @77 Ft. Lbs yet in the Mustang Manual the strut bolts require 148 Ft. Lbs to secure them so i am a little concerned that these bolts are either wrong or at the very least they will not hold 148 Ft. Lbs of torque.
Richard
Old Jun 15, 2006 | 05:48 AM
STANGSUSPENSION's Avatar
STANGSUSPENSION
Former Sponsor
Default RE: Camber Bolt Question?
Yes they are the correct bolts, 81260's are the 05-06 bolts. It may not say Ford because camber bolts are "generic" in nature, and fit many models and makes of cars.
They go in the top bolts. The reason you dont torque it down as much is because of the way the bolt is designed. Just follow the instructions on the bolt kit and you should be fine.
We have many many customers running these bolts...
Sincerely,
Old Jun 15, 2006 | 12:07 PM
06GT4RAD's Avatar
06GT4RAD
Cool Thanks and just wanted to make sure.
RIchard
Tivo304
Aug 28, 2023 12:19 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
04stangman
Sep 17, 2015 01:45 PM
RWHEELS
Sep 5, 2015 03:42 PM
